1 - 4 of 4 Posts
Hi another problem with our car... starting to hate it now..
We drive along and some times the car will just cut out..I have noticed it seams to be when we slow the car down at say a set of lights and the revs drop the can just cut out...and we have to restart the car..
The car is a 2002 320ci Auto
I have so far changed the
Plugs
Coils ( 6 )
as yet to change the fuel pump relay
As yet to change the fuel filter.
:hmm:
had a similar problem with my pug. try disconnecting the battery for 10 mins and it may reset the ECU settings. then go and get someone to do a diagnostic check for you as fault(s) should have been logged on the ECU. that should tell you what you're dealing with and how to overcome it :)
Go get your DME reflashed at the dealership. They have an update that will fix the problem. I had the same problem and it got fixed with a reflash.
1 - 4 of 4 Posts
