Good evening (morning) all!
Tonight, I was feeling inspired to once-and-for-all solve my sticky door handle problem (front, passenger/right side) on my 325i sedan (2003 if it matters). Lurking in past threads and surfing the Youtubes, I discovered what sounded to be the easiest of all fixes: tighten a hex screw underneath a little plastic cover on the latch of the door. Here's a thread from the past here in e46fanatics (Door handle difficult? Try this.).
So, I tightend the screw a little bit, and it didn't really seem to make a difference. So, I did what any reasonable person would do and tightened it some more. Still no major effect (or maybe just a little difference which was probably placebo effect). I tightened yet again, closed the door, opened it, and still not quite enough. But this time, it seemed that the hex screw wasn't quite returning to it's "normal resting place", so I waggled it with the hex wrench and it returned to "rest". I tightened once more, closed the door, and now YIKES, I can't open the door at all. Seems that whatever I adjusted, I adjusted it too much. And, to make matters worse, now the inside door handle won't open the door either.
Semi-panicked, I went back to the Youtubes and the Fanatics threads and saw a detail I'd missed before: People talk about first loosening the screw before tightening. I mean, that doesn't really make any sense, but indeed I did not do that. And, I'm stuck where others were joyful at their easy fix experience.
I'm not afraid or unable to throw parts to fix this door, but my first problem is: How am I going to get this door open?? All the DIY guides and videos out there start with pictures or descriptions of the door being open before repairs begin (either the interior or exterior doors seem to work). Or, they're about Coupes with door handle problems, but the Sedan seems to have different mechanics. Can the interior door panel be removed while the door is closed?
Seems like this should be a common issue for all the door handle problems out there, but no amount of searching (yet) has yet uncovered this particular combination of:
Door is closed +
Exterior door handle won't open the door +
Interior door handle won't open the door +
Door panel is installed and intact +
Car is sedan
Really hoping I'm not going to have to go Beast Mode and rip the door panel up to get into the door. Maybe I can pour a gallon of lubricant into the exterior door handle and something magical will happen?
Help?
Door is closed +
Car is sedan
Help?
