with the impacts it has already absorbed I would not be surprised if it didn’t already compromise its integrity on the bearings/seal.I think at this point the water pump's going to be sacrificial, too...
Too much metal powder dust!!!chanting saw-zall, saw-zall, saw-zall
I too believe this is the quickest solution. Find the longest hacksaw metal blade you can find and go to town. Have a long chisel available as well in case the sawzall doesn’t go all the way through the bolts. Good Luck.there isn't.
This is exactly why Milwaukee makes the sawzall.
I fear.
t
I like pneumatic hammer with a pointy end To remove that nut.While sitting in a drivethru my serpentine belt came off the pulleys somehow and I completely lost power steering and alternator I'm guessing. Anyway I tried removing the fan but it just won't budge. I'm using the correct tool and am aware it's reverse threaded as I have removed it once before years ago. While trying to get it off I managed to crack the water pump pulley where it's going to crumble with any more pressure. I tried then to remove the hex screws but 2 of them are stripped, I'm thinking from the previous owner. I got a replacement metal pulley for whenever I can get the fan off. I am not sure where to go from here, any help would be greatly appreciated.
Take a blow torch heat the area until hot then try to take it off.I've been wacking at it with a hammer and using penetrating spray. Like mentioned I whacked it so much that I cracked the water pump pulley that the other part of the tool uses for leverage. I think the bolt is seized from heat since I have a coolant leak somewhere as well.
How do you point the torch bottle down close to the nut with no space? Maybe setting a fire with paper towels dropping like parachutersTake a blow torch heat the area until hot then try to take it off.
My buddy who is letting me borrow his car has one that he is offering help with. In about a weeks time I'll be done with this semester and get right on it!OP, if for some reason the belt method doesn't work for you, you can try heating the nut as previously mentioned. if you have a common propane blow torch, or better yet, one that uses MAPP gas, you can use a blow torch extension to get heat on the nut. Blow torch extensions are very common in the plumbing world where you can run into clearance issues when trying to sweat copper pipes. $32 from Amazon.
Propane Torch with Hose and Three Burners, Portable Propane Torch for Soldering Welding Heating Plumbing, Mapp Gas Torch with Flame Control, Handheld Propane Torch with 50" Hose & Replacement Burners - - Amazon.com
Propane Torch with Hose and Three Burners, Portable Propane Torch for Soldering Welding Heating Plumbing, Mapp Gas Torch with Flame Control, Handheld Propane Torch with 50" Hose & Replacement Burners - - Amazon.comwww.amazon.com
Nothing yet! It's finals week in my university so was planning on working it all out in about a weeks time when I have time. I will for sure post a follow up in this thread after first trying the belt trick, then heat, then air hammer if anything before looking for another vehicle.the OP hasn’t been active in 5 days.
although curious what he did to remove. looks like we may be wasting our time
