1 - 7 of 7 Posts
These are the symptoms:
- Car blows 'luke warm' air only despite temp maxed out to 32/C and engine heated up :thumbdwn:
- No change even with A/C ON or OFF :thumbdwn:
- Cold A/C is working fine :thumbup:
- Temp gauge is working fine :thumbup:
Anyone have any idea what's gone wrong? :dunno:
Winter is coming and I am fabsolutely freezing! HELP!!!
sup
does it start out warm and get progressively colder?, that could be the ikha climate control fan is dead, otherwise may be a bad heater contol valve.
I just recently had to get the 'final stage resistor' replaced from the dealer cause the blower fan wasn't working. Same symptoms - little to no heat...
Discussion Starter · #4 ·
The strange thing is that when the engine is cold, the air is cold as normal. It then gets progressively warm but it then stops there and never gets hot. Icy in London right now...
Discussion Starter · #5 ·
Was it expensive, and did you fit it yourself?
I believe it was a $70 part, install 3/4 hour. Don't know total cost because car was under warranty. This should give you an idea though.
1 - 7 of 7 Posts
