Bottom Line: 2001 325ci conv. ZF transmission went out. A few years ago I had to replace the engine and did so with a 330. I'm about to buy a transmission and have the shop picked out to do the work but they asked very good questions about the switch. They don't do mod work and don't want it to go bad.
Since I already have the 330 engine (no issues putting it in), can I go ahead and replace 325 trany with 330?
Questions the shop is asking...that I can't answer:
Does the linkage sit up/back is it going to line up?
Is the length of the driveshaft the same?
Linkage/Crossmember going to be ok?
Basically...will the 330 transmission bolt up simply with no mod?
Could really use you guys help. :bow:
I'm scared to buy and ship the wrong transmission but would REALLY like to use this opportunity to switch out with 330. I'm one step closer to having a 330 in my garage. All I lack are bigger brakes at this point if I get the new trany. Thanks!
