Can driving 4miles with an expansion tank separated at "weld" seam damage the engine?
Hi folks,
Recently I was sitting at a red light I heard a popping sound, right after the light turned green I pulled over and saw some dripping of what looked like coolant close to the passenger-side front wheel well. I drive a 2005 M3 SMG.
I checked the engine temp gauge it had moved slightly to the right of mid-point. (it normally sits at exactly mid-point). I decided to drive the car straight to my repair shop which was about 4 miles away. I was watching the temp gauge the whole time, and as I started moving the temp went almost perfectly back to the normal (mid-point). During the drive the low coolant light also came on.
When I got to the repair shop I popped the hood and noticed the top of the expansion tank had popped, and I could still see coolant below the float.
I got the car back after replacing the coolant tank, it runs beautifully and the temp gauge runs exactly at mid-point when it's running. At the repair shop I was told that engine had recorded the fault code "Engine Temp Implausible" several times. And the cooling system and engine may have suffered damage, but they found no evidence of it or any other fault codes.
So I am quite worried that maybe the engine heated more than the temp gauge was show during the 4 mile drive to the repair shop. And I have two questions, that may (or may not) help me worry less.
1) When the expansion tank pops at the seam, does that cause all the coolant to leave the cooling system? I know the M3 cooling system runs at high PSI, but I thought it was the excess coolant that this tank stores.
2) Does the engine temp gauge use a sensor that is independent of the coolant temp? If the coolant level had gotten really low is the engine temp gauge still reliable? I worry that may be engine was overheating and it was not showing the right temp.
Now I am starting to think I should have had the car towed for the 4 miles, but I thought I was being responsible by watching the temp gauge.
Would appreciate feedback from someone who really knows how an 2005 E46 M3 cooling system works.
Thanks.
Hi folks,
Thanks.
