1 - 20 of 22 Posts
· Registered
You can tow a Mercedes or a BMW if you have the key in the ignition and the car in neutral. However, it's quite difficult (if not impossible) to tow a BMW or Mercedes without the owner's permission. I know that Mercedes has special tow trucks that lift the cars up onto flatbeds.
· Big Baller - Shot Caller
Yes of course they can be towed. There is a tool in your trunk that screws into the bumber.
Benz's can be towed to, as can any other car. But you do want to put your e46 on a flat bed. No way is a tow truck going to be tragging my M3 behind him on a hitch.
· In Pursuit of My J.D.
A flat-bed can tow both the BMW and Mercedes, but I think HellFish is asking about a non-flatbed tow truck. I know that on my Mercedes there was an anti-tow feature that I didn't know how it really worked...there was a button on the dash that allowed the car to be towed; I'm assuming the wheels lock up when parked.
· Got Mis-shift?
10chi said:
thats odd, I have seen both Benzes and BMWs being towed away by city tow trucks. I seriously doubt the owners were there to let that happen.
Yeah, those city tow trucks have a special towing equipment that they put under the wheels. It basically put the car's wheels on a skate board. I've seen it so many times in sunset blvd.
They lift the car and put the skate board on each rear tire and just lift the front. I've seen them tow benz's and bmw's.
· SBBMotorwerks
Well, i had my BMW towed one time. I had locked my keys in the car (it was my only set of keys). My dealership said i had to tow my car to them so they could open it.
So the tow truck lifts my car from the rear and had to make sure my front wheel were locked (not from spinning, but from turning). Once he did that, he towed my car. I was paranoid the whole time.....but nothing went wrong...my car is perfectly fine.
So, yes, it is possible to tow a BMW
· Registered
My car had a hit and run, and they broke the front links fo the driver side wheel.
the car was lifted form the front and rolled the rear. My car is manual so it was put in neutral. it was only towed for about 5 miles but there wasn't any problem.
· Pwner
sometimes they don't even do that.. here at duke they're really stingy about parking. this one car apparently had the anti-tow feature and they just tied the chains and pulled it out of the spot onto a flatbed, even though the wheels were skidding on the ground.
· Read Only
well i will tell you this
found out that the 3 series and the m3 need to be flat beded.
that is why they have the hook on the bumber. that is so the flat bed can pull the 3 series on the flatbed. if you towed the 3 series you will f--k it up don't try it.
bobm3 ;) ;)
· Registered
all they have to do is pickup the rearend with a tow bar that fits on each side of the rear tires and tow it that way (for RWD), if the front wheels are straight the key does not need to be in the ignition or the tranny in neutral. If the front wheels are turned most tow trucks have dolleys they can put under them. Taking your BMW is no problem for an experienced tow truck driver.
BMW recommends flat towing, but if a repo man, etc. is after your car they will take it any way they can.
ps: the hook that screws into the bumper is for pulling you out of the snow bank, ditch, etc. not for towing you down the street
· Registered
At an appt. place around here they are retarded like that and tow you if you aren't in the right place, but there aren't enough guest spots. Anyways, I have a manual and I always back in, and I use my E-Brake. There is no way they could tow my car right? They don't even use flat beds. But even if they did use flat beds, they still couldn't right?
· Pwner
read my post. they don't care. you cant stop them. theyll just drag your car onto their flatbed.
· Registered
Any car can be winched onto a rollback truck and taken away or one in lifted and other end lifted onto tow dollies.video link below
· Registered
Wrong, they would hook to it with a wheel lift and drag it out of the spot then put it on dollies. Watch the link i post.
1 - 20 of 22 Posts
