1 - 4 of 4 Posts
Now I know the car doesnt have enough power or aerodynamics to make this happen but according to this gearing calculator it is theoretically possible putting aside power and wind resistance.
I factored my 255/35/18 rear wheel and got a tire diameter of 25.0 inches. Then I factored the .85:1 sixth gear. Then I factored the 3:07:1 differential and kept plugging in numbers in the speed column until it reached the 7000 rpm fuel cut off of the car.
Heres the RPM calculator:
http://www.quiknet.com/~ke6vut/rpmcalc.html
Heres the Tire Diameter calculator:
http://www.miata.net/garage/tirecalc.html
if u tow it with a ferrari may be. Wind resistance is huge at that speeds. To get from 150mph to 180mph you need like +80hp. it increases exponantely
Discussion Starter #4
gokcer said:
if u tow it with a ferrari may be. Wind resistance is huge at that speeds. To get from 160mph to 180mph you need like +80hp. it increases exponantely
Did you even read the whole thread? Read it again slowly and carefully
1 - 4 of 4 Posts
