1 - 7 of 7 Posts
My car is idling very rough, sometimes car acts as i m pushing the gas without pushing the gas and RPM passes 1000-
Idles very low and in the morning it popes noises.
Misfires on all cylinders, i changed oxygen sensors, MAF sensor, ignition coils, IDC and seafoamed my car and still same problem.
Should i change my exhaust camshaft sensor?
Camshaft sensor causes misfire on all cylinders?
Camshaft sensor causes low idling?
1. P1397
Camshaft Position Sensor "B" Circuit (Bank 1)
2. P0130
Powertrain: HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1
3. P0150
Powertrain: HO2S Circuit Closed Loop (CL) Performance Bank 2 Sensor 1
4. P1189
Fuel Control (Bank 2 Sensor 1)
5. P1188
Fuel Control (Bank 1 Sensor 1)
6. P0302
Powertrain: Cylinder 2 Misfire Detected
7. P0303
Powertrain: Cylinder 3 Misfire Detected
8. P0301
Powertrain: Cylinder 1 Misfire Detected
9. P0304
Powertrain: Cylinder 4 Misfire Detected
10. P0306
Powertrain: Cylinder 6 Misfire Detected
11. P0305
Powertrain: Cylinder 5 Misfire Detected
btw if you're doing cam sensor, i'd replace them both at the same time
from my experience the other one usually goes bad shortly after the first
gl
Are these the codes from your OBD 2?
Why did you replace all those other things before doing # 1 on the list?
Discussion Starter #7
that's what i was thinking:hmm:
I have 95K on my 323CI-
So time to change 4x Oxygen sensors and the sparkplugs.
I have another E46 so i just swapped the MAF - Ignition coils -
and i dont know why i changed the IDC -
Now i need to know if the camshaft causes any misfire! i have misfire on all my cylinders -
Those codes from OBDII ( lapotp software )
1 - 7 of 7 Posts
