1 - 9 of 9 Posts
Hi.
Please I would like some quick answers.
My motorlamp just came on, we read it and it said:
" 0A: camshaft position sensor error code, wrong signal to crankshaft " or something like that.
Car runs fine, no limp mode.
Is this a sign of the sensor itself beeing bad or something else like a crack in the exhaust or anything?
I did order a new sensor but I would like to know if the code could mean something else beeing "broken".
Thanks alot!
/Filip
was the code p0369? had the same problem a month ago. just bought the sensor and o-ring and swapped them out. pretty easy diy. theres a write up somewhere on here about it
Discussion Starter #3
Didn't read it @ BMW, just some local dude on his laptop.
The only code he saw was 0A :eek:
well well, the errorcode was: " 0A: camshaft position sensor error code, wrong signal to crankshaft " or something like that.
When you replaced the sensor, did the light go out by itself or did you have to let BMW erase the code?
Thanks for the answer!
Formerly know as phatbimma
Which one did you replace Filip the intake or exhaust side? Did you find a DIY somewhere?
My intake one needs replacing which I think means the intake plenum has to come off.
1 - 9 of 9 Posts
