1 - 6 of 6 Posts
Top2Bottom
Whats up guys....
So i have had my UUC v.2 for 3 days now...and i swear every time i look at the car its lower....and i love it....
but......
as i look at it it seems as if my tires are getting more and more angled in..... so this means i need a camber adjustment right????
So i guess my question is...what does this involve??? Do i need to get new camber plates or anything or what??? Any help would be great....
thanks guys.....
kevin
PSHOPWERKS
Yep, you're up for an alignment job (if you haven't gotten one after installing your springs). If it still is tilting inward, then you may opt for a camber it. But usually, an alignment job will alleviate your problem.
Top2Bottom
Discussion Starter · #4 ·
alright thanks guys...that is what i was hoping for....cause i look at it and im just like damnit why cant anything be easy..... so ill let the springs settle for a while and get the alligment and hopefully that does the trick.... thanks guys!!!!
kevin
St. Louis BMW Fanatic
Let the springs settle and then take it for a 4-wheel alignment and check the alignment report to see what your camber is at. If the camber is really negative; consider getting camber plates...but normally it's not necessary unless you really slam your car. Remember; you want to run a little negative camber.
Good luck. :D
1 - 6 of 6 Posts
