1 - 6 of 6 Posts
i Went for a wheel alighnment and i was told they werent able to fix it perfect because i needed a camber kit...wat camber kit does everyone recommend?..thanks :thumbsup:
Discussion Starter #3
the inside of my front 2 tires are gettin worn out faster then the rest of the tire so in order to fix it straight and complete the alighnment i was told i need the camber kit
Nope - you need to change your toe setting. I've got -1.1 deg of front camber, zero toe, and very even tire wear.
What are your camber and toe settings?
Do you know that the factory pins must be removed from the shock tower to allow chamber adjustment? Is your car lowered?
1 - 6 of 6 Posts
