21 - 37 of 37 Posts
Discussion Starter · #22 ·
The common failure points for the E46 cooling system are not the connection fittings. The coolant expansion tank, in my experience, is a much more common failure point. In my cases, I've had to replace two expansion tanks, radiator and the hard coolant pipes residing under the intake manifold. I have never had a failure with the connection fittings of the coolant hoses. Now to be fair, when I replace the coolant expansion tank, I also replace the coolant hoses because I'm there already. I've had my car from 82k (2011) to now 235k
If you're a new E46 owner, there are a couple of links that you may want to read up on:
Edit: I've also had to replace the water pump once and the thermostat once.
Thanks for all the information guys. I'll read over the links.
even the double ringed hard pipes felt sloppy and were all genuine parts direct from bmw park lane london
Sloppy? These 2 pipes were bolted to the block. I like to see a video showing the pipes were sloppy around when pushing with a finger.
2001 325i Sedan
PSi would prefer 2 Orings.
You mean just like on the brake master cylinders, and calipers?
Oh, wait a minute....
Just cause it makes you feel better, does not mean it IS better. To think you know better than the BMW engineers is a bit arrogant. Especially when you clearly have not even done any research to understand what things actually ARE potential problem areas. Going on "feeling", rather than facts, you will spend a whole lot of money, and make your car LESS reliable. My car went >195K miles with NOTHING but normal, scheduled maintenance, a water pump at 125K miles, and a fuel pump at 170K miles. And my experience is not at all unusual for these cars. As I always used to ask all the engineers working for me: Exactly, what problem are you trying to solve?
Thermostats and o-rings fail quite often. I’ve replaced my expansion tank 1 time in 200,000 miles.
I am sure you are right but sometimes you look at something safety related and think mmmm
Thermostats and o-rings fail quite often. I’ve replace my expansion tank 1 time in 200,000 miles.
I have replaced the tank twice and the O rings many times in 40 K miles,thats without all the other leaky cooling bits all now replaced with genune parts where possible and 2 water pumps.
Personally, I just don't like all that plastic.
It's a prejudice having grown up with much simpler plastics.
Yes, that's not my graddaddy's bakelite-
I still don't like the plastic.
The brake caliper seal's a square section in the caliper,
and a cup seal in the master. There may be o- rings in the
pumps, but I've never looked.
t
  • Like
Reactions: alan53
The parts the O ring services are a tighter fit from observation on brakes.
In all calipers, the O-ring sits in the cylinder's groove (same as the hose plastic connector with groove for O-ring) and the piston slides through the O-ring inner diameter. In fact I would say the brake O-ring is not compressed on the movable piston more than the coolant O-ring on the non-moving connector port.
And 29 psi max coolant vs hundreds of psi brake fluid, with just rubber O-ring.
Do you know that the hard working brake caliper has an O-ring to keep the brake oil from leaking around the piston when you step on the pedal hard to avoid rear end someone? Do you trust the brake O-ring?
It's not an o-ring.
It's not an o-ring.
Semantics. In either vernacular I would not use any typical O Ring composition in a brake caliper seal.
Agreed. I should have used the term brake caliper piston seal, but the idea is that to compare the brake O-ring seal and the coolant O-ring, and it is not the tighter fit in the brake vs. looser fit in the coolant design.
21 - 37 of 37 Posts
