I noticed a clanking sound a few days ago coming from the rear of the car. It's been driving me crazy. It sounded a bit like brake pads clanking around in the caliper after losing the retaining clip. Today I removed the wheel to look around and saw that the spring was broken and that the lower bit of it was sitting there inside of it. This is obviously what's been causing the noise.
The car is an XI. I don't want to lower it.
I've never had a spring break on a car before, so I don't know the procedure. The replacement itself seems pretty straightforward, but I don't know whether or not it's okay to just replace the one spring, or if I should replace both, or if there's anything else I absolutely need to replace at the same time. The rear shocks are newer, with less than 10k on them.
Also, the touring springs are slightly ($5) cheaper. Will they fit the XI? Does it make any sense at all to use them? I'm asking because I imagine they're supposed to be stronger to support more weight, and they might keep this from happening again.
I'm looking at these (regular XI): https://www.fcpeuro.com/products/bmw-coil-spring-rear-heavy-duty-e46-coupe-sedan-suplex-06047
Vs these (touring): https://www.fcpeuro.com/products/bmw-heavy-duty-coil-spring-rear-06213
