LOL, I saw that 30 years ago on a Chevy. Funny s#!t.Not sure if loose hardware, or just metal fatigue is to blame. I haven't seen this on an E46 personally, but have seen flex plates break in the center on other vehicles. As broke completely away from the rest of the flex plate right around the bolts on the crankshaft. One of them was just spinning the outer parts when you engaged the starter and was making an awful sound. The other actually spun and wedged itself back together and still started and drove. The flex was hitting something as it rotated, though, which clued us in to the issue.
I experienced with a Ford Expedition and a PT Cruiser. The PT was the one that wedged back together.LOL, I saw that 30 years ago on a Chevy. Funny s#!t.
+++1My best guess is that two of the torque converter to flex plate bolts were ever so slightly loose.
Automatic flex disc/flywheel to crankshaft - 121Nm (88 ft-lbs)What should the torque be on those 3 bolts?
Do you know how much clearance of the bolts to the flex plate holes? With no dowel pins between them and only 3 bolts at 33 ft-lbs, I would add Loctite on the bolts threads. The plate has 8 bolts around the center at 88 ft lbs each, and its outer only has 3 bolts with 33 ft lbs each, and the load torque is the same at the crank and the TC, so each of those 3 outer bolts carries a lot of load.Torque convertor to flex plate - M10 8.8 45Nm (33 ft-lbs)
Since the heavy TC could move fore/aft as the car accelerate or braking, and so the flex plate needs to be flexible. This probably dictates why it is a triangle/3bolts instead of a disk / many bolts, or square/ 4 bolts.bit off-topic, was there any logic on using only 3 bolts to secure the tc to flexplate?
If you look at them, they have the heavy micro-encapsulated Loctite on them. Definitely re apply!Do you know how much clearance of the bolts to the flex plate holes? With no dowel pins between them and only 3 bolts at 33 ft-lbs, I would add Loctite on the bolts threads. The plate has 8 bolts around the center at 88 ft lbs each, and its outer only has 3 bolts with 33 ft lbs each, and the load torque is the same at the crank and the TC, so each of those 3 outer bolts carries a lot of load.
