1 - 5 of 5 Posts
Alright, so I've had the common problems on my '02 325CI since I got it, but now, there is something new happening, and I don't know if I need brakes, or if there is more to the issue. Whenever I brake, and typically only under 15 MPH, the brakes sound as if they are rubbing against something. This same noise is made if I turn abruptly at the same, low speeds. It only happens when I brake so I'm not too sure... Any ideas....?
The metal backing might have worn through and is coming in contact with the rotors. Look at the rotors and see if you can see any visible marks on them. Most likely you'll need new pads, rotors and sensors.
1 - 5 of 5 Posts
