1 - 9 of 9 Posts
Are we there yet??
Ok so I have installed new pads and rotors (and brake pad sensors what a pain the back one was). Well anyway this isnt the first time I replaced my brakes, install quick and easy. But it seems that my pedal travel is a bit to far, car stops great, no problems with that, just the pedal travel is to far. Not sure how to correct that, bleed brakes??
Definitely bleed the brakes and do a flush while you are at it.
Super blue will eventually stain your reservoir so you can't see the level in it. They make a higher grade that is not blue too which is what I use, but I forget what it is called.
Motul 600
1 - 9 of 9 Posts
