After I installed my bbk, I had a buddy come over on Friday to give me a hand in the brake bleeding procedure. I started at the rear passenger side, went to the rear driver side, front passenger side, and finished up at the front driver side.
When I was bleeding the first caliper, we kept hearing a squishing sound. Upon inspection, I realized that I didn't have the hard line and coupling on the front driver side tightened all the way. As a result, the reservoir went totally empty on us. I fixed the issue, and we proceeded to re-do the bleeding procedure.
Everything went smoothly on the second try, but now I'm worried that I got air in the ABS system or something and the car won't be safe to drive. I read somewhere that if the reservoir goes dry that the only option is to have it towed to a dealer so they can bleed the ABS system.
I haven't tried to drive the car yet as I still have a couple of loose ends to tie up before I put my new wheels on and take it on the maiden voyage.
Did I royally screw up by having the reservoir go empty? How much is this screw up going to end up costing me?
Thanks in advance for any help.
