I bought a 2005 vert with 132K miles a month ago and have been changing fluids on it over the past couple of weeks. Yesterday, I decided to do the brake fluid and used a turkey baster to inititally remove some fluid from the reservoir. I pulled out about 8 oz and refilled to max line with the same amount. I then went to start the car because I needed to reposition it in the garage. The brake pedal immediately dropped to the floor and the DSC and e-brake light (yellow) were on so I went to check the fluid level and it was down about to the middle and I refilled it again. I must have did the refill cycle a couple of more times before I decided to pour slowly and watch the level which was dropping back to the mid way point as well. I have now put in 32 oz and a 12 oz bottle and the brake fluid level remains at the same spot (middle of reservoir). There are no visible leaks anywhere and do not know where the fluid is going. I am completely baffled by this and would appreciate some guidance or help! Thanks in advance.
