1 - 6 of 6 Posts
Hi, I just bought a 318ci 2004. But I don't have the radio user guide.
And I heard that the volume can increase when i drive fast, anybody can explain ?
The volume adjusts itself depending on the speed you are traveling. My car's radio volume goes up a notch every 20mph of speed I go up.
Discussion Starter · #3 ·
What does it means SPEED VOLUME 0 to 6 ? which one should i select ?
And i dont know how to save the preset ?
Thks.
It's in the FAQ:
Q: How do I change the speed-sensitive volume control setting?
A: This feature allows you to decrease the speed sensitive volume with the HK system as well as put your radio in different country modes (such as Europe mode). This doesn't work on all radio options, but give it a shot:
On cars without NAV
First, don't be driving while doing this procedure.
Turn the radio off then on again. Dont touch any button except the 'm' button - the button you use to tune the radio frequency manually. Press and hold the 'm' button for TEN seconds or until the display changes. IIRC, it shows the serial number of the unit. Normally when you press 'm', the display will reflect that by replacing 'ST' (stereo tuning) with 'm'. When holding the 'm' button for this procedure, the display should not do this - you will continue to see 'ST' for the ten seconds.
Now if the display has changed, you are in a configure mode on the radio. If you press the '+' or '-' button you change modes. The mode you want will display as "GAL (1-6)". This mode allows you to adjust the speed-sensitive volume control. Use the radio preset buttons 1-6 to set the amount of volume change you want at speed. Setting 1 is the smallest change, 6 is the highest.
I use 1 with the windows closed, and 4 when it's a nice day and I drive with the windows open which makes for a lot of ambient noise at speed. The car is so quiet with the windows closed that setting 1 is plenty. On my car the default setting from the factory was 3 and it bugged me too.
Then turn the radio OFF to save the settings. Turn it back on and go for a drive to test it. The other semi-useful test mode will tell you the signal strength of any give station from 0 to 15 (highest). Use the preset buttons to change stations in the mode. This capability is probably used in the automatic tuning funtion in the radio.
On cars with NAV
Get in the car, close the door, and turn the ignition to position 1 (accessory. As soon as the monitor comes on, press and hold the RDS button for aprox 12 sec. Using the arrow keys, near the Tone and Select buttons, scroll to heading "GAL" (German acronym for speed depandant volume) The default setting will be displayed. To change, use the number keys 1-6, 1 being less increase, 6 being maximum.
Best Regards,
Ralf T
1 - 6 of 6 Posts
