1 - 10 of 10 Posts
Hi everyone, I'm new to these forums and new to tuning BMW's so please just assume I don't know much in your answers. I recently ordered an M3 steering with with associated round airbag. I did the install, got the steering wheel on and came to installing the round airbag itself. All the connections were in place (2 in the steering wheel, 2 in the airbag). HOWEVER, when I placed the airbag into place, it clicked into place but it wasn't flush with the rest of the steering wheel. There was about a 1/4 inch gap between the airbag and the rest of the steering wheel. I just assumed this was how it was supposed to be until I turned the ignition key on and the horn went off constantly. I turned the car off and back on multiple times with no different results. Really this comes down to 2 things, how do I get the airbag flush with the steering wheel and why is the horn going off? Thanks for any help you can give. Picture is attached.
Is the wheel brand new? Probably bent if it's a used wheel, you can see if it's bent or not by removing the wheel from the car and placing it on the flat surface.
Discussion Starter #4
The wheel is used but I put it on a table and it balances so I don't think it's bent...wouldn't it be a problem with the springs or something inside that keeps it from going in farther?
Unplug negative battery terminal in the trunk.
Then use a flathead screwdriver to compress the retainer springs that hold in the airbag. Do this by pushing in almost horizontally, just a bit more vertical.
Remove airbag.
There are two springs in the top left and right corners. The screws that adjust them should not be fully tightened. Loosen them a little bit so the horn is not so sensitive.
You're gonna have to play around with this a little bit by reinserting the airbag and hooking the battery back up. Then repeat if the horn is still sensitive.
Hope that helps.
Discussion Starter #8
Well I expected a little gap...but that much? I can physically wiggle it...if that's normal then I'll adjust those screws. Thanks and keep posting advice!
The metal receptacle might be bent. Take it out by removing the 3 screws and take a look. I don't have a picture of how a new one looks like, but what I did was just try to bend it back a little, since it was sticking out. With a few trial and errors, it fitted perfect.
sorry to resurrect this but what's the fix for this one? is it as KYC has explained -- bending the receptacle?
1 - 10 of 10 Posts
