1 - 4 of 4 Posts
· Registered
Hello,
The bentley service manual seem to be advising to use a power bleeder AND depress the brake pedal 5 times (p.691).
ECS tuning tutorial
The above tutorial however advises against depressing the pedal and using the power bleeder as a substitute. They say depressing the brake pedal could damage a used master cylinder due to the piston reaching further in the cylinder and accumulated debris that could be there.
Any opinions ? What is best and why :tsk::hmm: ?
Thanks ,
E46M3ZCP
· Registered
I have done both (not together) - but now use a power bleeder. If you plan to use the pedal method - put a piece of 2X4 flat under the brake pedal. You don't want to press it to the floor - to avoid damaging the MC. The power bleeder should do everything you need.
1 - 4 of 4 Posts
