7561 - 7580 of 8152 Posts
What is best step by step tune? (ex. AFR-> Disa -> ignition -> Vanos)
And what about safe AFR on WOT? Im pretty sure its good gain, if make it leaner, but how much?
I also want tu swap intake cam on my m52b28tu from m54b30, and already have m54b30 intake manifold and catless china headers. Maybe someone have same setup and could help with changes in maps, related to cam upgrade?
Log the engine with wideband (preferably on both cylinder banks) or if budget is low disable the full load enrichment and log lambda trims in idle and partload. then adjust your injection tables accordingly. (Engine will run lambda 1.00, so be carefull and retard some ignition angle at high load.
Activate full load enrichment again and scale it to your needs. Increase timing where you need it and hear/log for knock.
Then do two WOT logs from low rpm to limiter with DISA fully opened and fully closed, plot them in your favourite tool (MLV or Excel) and see where the lines cross each other. (Propably around ~4000rpm)
Then do VANOS tuning or copy from B30, it's upto you.
Hi! Can I ask you few questions. I cant find the answears. I have Ms43 Mb54b25. I use chipster MSS5x Flasher. I made a partial read. Open the ecu with tunerpro rt. . I am loading MS430056 xdf but maps are still without names and I cant find the tables to changes...
You have to do a full read first. Save this in multiple locations and name it stock.bin. This is your stock bin that you can reflash incase you do something wrong. Then you have to flash the full 512kb bin file to 'unlock' the dme. Once thats flashed read the partial and load that in tuner pro
friends i need your help please
my car is a 320i 2003 ms43
today I made my first attempt to change the software for version 69, my original software was 56
I downloaded the version 69 file and wrote it with the ms4x tool, the car started without any problem
but if I open the file in tuner pro with the XDF Siemens_MS43_MS430069_Community_Patchlist.xdf
and made some modification, for example activate the patch for immobilizer bypass and check sum bypass patch and make full write again the engine only cranks but wont start
already try removing the immobilizer patch and only use the check sum bypass patch and it is the same result, engine only cranks but wont start
I want to use the immobilizer patch since my key stopped working to close the car and open the trunk, so I bought new keys which I could already configure to work with the alarm but obviously the engine does not start with them, I want to be able to use them to start the car
I would like to know what prevents my engine from starting when I apply any of the patches, I don't think it's a problem with the check sum since the temperature needle stays on the blue side
please help me
Because Race...Convertible?
Turbo ZHP Convertible
Dont see why you'd need either of those patches
Then find someone with an AK90 key/ews programmer that aligns your keys to the immo module :)
ok, And why not make the damn thing work?
I prefer an answer that is willing to help solve this and that works as it should, so for the launch control I better buy a wotbox or a beeR?
even Better, I remove everything and use megasquirt
this was supposed to help other enthusiasts to be able to work with this software and the ms43, not be mocking
Wow, calm down. The EWS delete was initially created to make it possible to swap an M54 engine into other non-EWS chassis. Not to fix problems introduced by other non working peripherals that can be fixed up with very little effort.
I successfully tested 430069 on at least 15 cars with every displacement version of the M54, so guess what, "the damn thing" works. Simply flashed with MS4X flasher, no boot mode, no hassle.
Everything published on MS4X is meant to be understood before any tool is started, firmware is flashed or bit is changed.
You mentioned the word "enthusiast". A real enthusiast reads through as much information as possible before blaiming the hard work of others who do all of this in their free time.
This includes reflecting your own ability to understand how this stuff works and when it's time to start over with reading and learning.
I'm the last person that refuses to help, but it pisses me off when people make us responsible for their own mistakes and shouting it into the public. Especially thinking that we HAVE TO make something work. We don't.
If you want to take the MegaSquirt route, nobody will hold you back. It's your decision, but I don't think it will be less work in the end
Otherwise, what steps have you done yet?
I am not blaming you for anything, I simply mean that all the answers I have received are: why do you want to do that? you better do this, in the other thread a guy answered me with an insult in Spanish
Of course I am a good enthusiast and it is not my first time relating to this type of thing, currently also tuning my DSM and my focus ST so I am not so lost
I have read every word on the ms4.x net at least 15 times, I have already read all the posts in this thread and the other
The steps I take are:
1- read my ecu in boot mode with jmgarage to have a full back up (just in case)
2-write the file 0069 of the wiki using the MS4x flasher in full write mode (engine starts)
3- activated check sum and launch control patches and write again in full mode with MS4x (engine does not start)
4- activate the EWS patch and the checksum patch, write again in full mode (engine does not start)
5-use only the check sum or EWS patch, write in full mode (engine does not start)
6- use only the launch control patch, write in full mode (engine starts but the launch control does not work)
I already tried also editing the check sum to 165 as mentioned in some posts but it makes no difference
also try sync ews with inpa or with the flasher when car dont start but it doesn't work either
I also tried to erase the adaptations and dont make any difference
None of that has worked, I don't know what I'm doing wrong since I do everything according to the steps that are mentioned in the wiki and in all the posts that I read
i always get dtc 115 TPS adation from inpa when engine dont start
So far so good, I like the fact that you did a backup. :clap:
For the EWS delete to work, you don't need the checksum to be disabled, leave the CHK patch untouched please.
In the flasher options, do not tick the check box for "Disable checksum correction".
Please flash only the EWS delete and try to start the engine. If it still doesn't work, perform bootmode reading of the ECU and send it to me via PM.
In the very very beginning of this thread I remember I have had problems with the throttle as well. I could start the engine but it went into limp mode until I cleared all DTC. I fixed that with reflashing the partial back in the days.
I already tried that, just using the ews patch without touching anything else and the engine does not start, also try using only the checksum patch without touching anything else and the engine does not start either
I'm going to do it again and send you a fresh read in boot mode
Does the flasher look like the picture I attached in my last post?
Edit: Please also clear adaptions after you flashed and power cycled the ECU.
dont worry i already make sure the ckech sum was enabled
every time I made a flash I checked that the check box was not marked
I even tried checking the box and performing the checksum with the checksum corrector that is on the wiki but it also not worked, it made no difference
Hello! Installed the dashboard on the e53 b30 from the e53 b46. I applied the patch M Cluster LED Control, changed the checksum, filled it back in the dme, but the lights did not work (Do I need to finalize something else?
i am also interested in the solution to this because i am kind of facing the same situation as the other gentlemen.
will read through and pay attention to your guys replies
... so I was fine tuning the vanos settings while I could notice no difference in partload pushing or fuel economy... I did a log test drive and noticed that the Vanos intake only delivers around 97 degrees (nominal at 118 for example) at 100-200 kg/h of maf reading and at around 2-4000 rpm...
Going with less load produces the values I typed in, going full load gives the output I desire.
Also tested it by turning FL Vanos intake completely to 126 to see if the DME somehow steals the FL values for PL and finally also totally turned off FL.
All exhaust values are around optimum!
Can I assume that the Vanos unit is faulty, did somebody else some part load logs around highway speeds?
By the way, the throttle response with FL off is nice, I will adapt the FL injection a tiny bit, atm it’s at around 12 afr.
Edit: I put in some crazy values and the Vanos system approaches them a lot more. I’ll be working with them now
Gesendet von iPhone mit Tapatalk
Thats strange. Usually if the vanos is not working properly it wont work at all and be stuck at its default position 126x-105 and give check engine. You said you adjusted FL im asuming thats full load. Maybe by adjusting your FL values dme does not go into full load vanos map and instead stays in partload and vice versa.
I have to edit this:
Around some load values the DME gives “wrong” target values. The Vanos reaches the nominal settings more or less.
If I throw the partload around 118 in the DME accepts them. Now I have to gradually step down until the sweet point.
Nice to know: I set up the last three positions in the FL map at 126 (b30 intake cam), the power is nice and maf values are being reached from the second to fourth gear (560-580 kg/h). Car pulls quite strong ip there. Peak power seems to be around 6500 rpm while it drops a few bits at 7000 rpm
