download the 64k file from your ecu and open it with a hex editorAlright. I'm trying to wrap my head around all this.
I've tried to find it but apparently haven't been able to.
Can someone please explain to me how I find the software version of my Dme so I'll know what xd to use? I have a bench set up and a spare dme to play with before I start on my car.
Thank you
Wiring diagram for MS41:i'm installing the next days an lc-2 wideband lamda.
i have cat configuration "1" since i don't use cats, so there are only 2 pre-cat sensors.
can i put the wideband in one post-cat position without changing cat configuration?
So this is the latest file? May i upload it to the wiki and write some instructions?
I'm seeing a ca430056.DATdownload the 64k file from your ecu and open it with a hex editor
correctI'm seeing a ca430056.DAT
So I'm assuming it's a ms430056 version?? Correct?
well if there is so much difference in polling, i'll use one pre-cat connection.Wiring diagram for MS41:
http://www.romraider.com/forum/viewtopic.php?f=42&t=13504
I'm running single-band pre & post cat, so I will attach the map to the precat bank 2 and the WBO2 to the postcat bank 2 inputs.
Precat polling is 10ms, postcat is 100ms, keep that in mind.
I hope that the DME will ignore the inputs for DTC, otherwise it would be pretty useless.
Do not connect the o2 sensor heating PWM ground to the normal KL31- Ground, otherwise you'll get errors for heater short.
Holy shit! absolutely amazing!getting closer.
I have sorted some of the digital data.
you can now trace idle and part and full load maps.
you have to setup each map to data tracing. see picture.
if it is a part load map select Part LOAD and Part LOAD RPM.
rename file to adx.
I only see movement on rpm not load in the video.
Engine was without load, so no changes on the x axis. ;-)ok there is a little misunderstanding about DA Assoc.
eg go to map "Intake cam setpoint, warm engine, part-load".
right click. select edit parameter XDF info.
select DA Assos.
X Axis DA Link. Link Mode = Explicit. Select X Axis DA Item = Part LOAD.
Y Axis DA Link. Link Mode = Explicit. Select Y Axis DA Item = Part LOAD RPM.
You must do this at all the maps you want to trace.
the adx works only with 430056 version?getting closer.
rename file to adx.
I do not know. I've only tried it with 430056.the adx works only with 430056 version?
okay. bench testing ;-)Engine was without load, so no changes on the x axis. ;-)
random question in tunerpro rt is it possible to import and export tables? i want to make my basic injection table identical to my cold engine part load map without having to change every cell induvidualyokay. bench testing ;-)
yes, copy pasterandom question in tunerpro rt is it possible to import and export tables? i want to make my basic injection table identical to my cold engine part load map without having to change every cell induvidualy
