1 - 2 of 2 Posts
Discussion Starter · #1 · (Edited by Moderator)
Hello,
I am replacing my driveline bushing, which includes the Guibo, CSB, and trans. Will do the engine later along with a rear suspension refresh with subframe reinforcements. I want an OEM to feel in the car with a slight performance increase in the suspension (don't we all). Which brand transmission mounts should I go with that is rubber?
options: Corteco, Lemforder, Myle HD
If it helps, I plan on going rubber engine mounts too, along with rubber front diff mounts, poly powerflex rear diff mount, stock rubber rtab with limiters, and poly subframe mounts.
I am pretty sure they are shot, so anything would feel like an upgrade, but I want the car to feel intact and not sloppy. I also plan on doing parking lot skids in it in the rain and etc.. when everything is done and all.
I have an 01 325Ci Verti. Thanks.
Premium Member
Most engine mounts (trans too) are Corteco.
Lemforder will be perfect for the rubber bushings.
1 - 2 of 2 Posts
