ok, here goes.
car is DD, suspension is H&R Cupkit.
rear shocks i think are shot, they just dont have the high speed dampening of the rear wheel like they used to, and i can see where the upper/outer sleeve is rubbing on the lower/inner one.
car has a huge and heavy wood reinforced fiberglass enclosure that pretty much takes up the entire trunk, + a 13W7 so that alone is 60 lbs, plus 2 amps and LOTS of dynamat and a few more things. i estimate atleast 200lbs in the trunk. I rarely, rarely ever have anyone sitting in the back.
Car will most likely NEVER see the track, but gets driven very spiritedly around town. I love the ride of the cup kit, but i wouldnt mind the back being a tad stiffer on the compression side, rebound is ok, or was ok, before the shock started being weird.
I DO NOT know what model shock the cupkit comes with, i think its a custom setup made by Bilstein for H&R, im trying to keep this cheap and easy, i WILL NOT have time or the motivation to remove the system later on and adjust or replace the shock, so i want to do it now while the system is out and the amp is being repaired.
Ive found everything pretty cheap online form Tokico HPs for under $70 each, Bilsteins HD, and sport for $80, and touring for $55 , to Sachs for $90, KYB GR-2 for around $50. Im on a tight budget, id like under $80 each shock, because fixing JL Audio amps aint cheap.
What do you guys think, if youve had experience with any of these REAR shocks on your BMW and or changed shocks on your Cupkit, youre input would be immensely appreciated. However, if you add anything, please tell me what you had the experience with, shock type and car, and the type of driving it was used for, and setup if anything other than stock was used.
BTW, im running a staggered setup on square tires, currently 255/35 and 245/45, the fronts i run as thin as 225, up to 245, and try to stay with 255s out back.
TIA...
TIA...
