1 - 10 of 10 Posts
I understand the concept of having a more complete burn. But are the stock coils bad?
Does anyone have any power numbers to support $250 to upgrade from stock coils?
the stock coils are good enough for the M3 models with 11.5-1 compression..... should be fine for a lowly 330/325 :)
Part Cross-reference
RealOEM.com Home
Language:
Part 12131712219 (Ignition coil) was found on the following vehicles:
E46: Details on E46
E46 320i Sedan
E46 325Ci Coupe
E46 325Ci Convertible
E46 325i Touring
E46 325i Sedan
E46 325xi Sedan
E46 325xi Touring
E46 330Ci Coupe
E46 330Ci Convertible
E46 330i Sedan
E46 330xi Sedan
E46 M3 Coupe
E46 M3 Convertible
I got a set because my 328 has the older, more expensive, style coils...
Figured it was going to be slightly cheaper to just get the BavAuto set.
Doesn't feel like that substantial a boost, but I did notice a little bit better throttle response.
You would probably have noticed a little better throttle response with a new set of stock ones as well.
Yea, I realize that...
...but did you catch the part where I mentioned that they ended up being cheaper; since I've got the older, more expensive style, coil?
Yeah, mine uses the older style as well. I just had to replace mine (one was burned up) and I replaced them as a set. I won't use any aftermarket part in the ignition or fuel system.
1 - 10 of 10 Posts
