1 - 6 of 6 Posts
So I go out to the garage yesterday to head to the store and my 99 323i (130k) greets me with a loud "click click" when I try to start it. ugh
The on-battery indicator is green, and a quick multi-meter post-to-post measure was around 10 or so.
Hooked up the charger and set it to "start" mode and it started. Ok, good deal.
So I put the charger on it for a few hours and took the bike to the store.
Checked the charge a few hours later and it's at 13 and some change. Started right up. I'm thinking "just needed a charge and I'll be good to go tomorrow."
Fast-forward to this morning.
I go out to the garage to start it up and I'm once again greeted with the loud "click click" sound but nooo startie.
What think ye? Time to replace the battery?
I recently had the same exact problem and it ended up just being the battery. Been using the new one for a month or 2 now and everything has been fine. My old battery also showed green on the indicator and took a charge, it just didn't keep the charge. I thought it might be the alternator but since the new battery has been going strong for so long I assume it was just an issue of an old battery. The battery I replaced was at least 5 years old if not more (it was used when I got it 5 years ago)
With the 10 volt reading after the battery sits, you may have a dead cell.
Is there any load on the battery? Something drawing current while the car is off?
I would disconnect the battery, charge it completely. Remove the charger and check the voltage after it sits unconnected 4 - 8 hours.
If it is down to 10 volts, you have a bad cell. If it is still fully charged, start looking for what is drawing current after you turn the car off.
Banned
Obviously the battery. If it's the alternator, you'll be going through this again in a week. If it was the starter, after all this, your car still wouldn't start.
have you measured across the (+) and (-) terminals while the car is on? That will also tell you if your alternator is charging the battery or not. Good luck.
1 - 6 of 6 Posts
