Is your battery located in the trunk? Because batteries under the hood have that L shaped bracket with long bolts... If its under the hood, then this part will not fit
Yes in the trunk. I have seen other e46 m’s with the L shaped bracket and others without it. Real oem does not indicate that the Al bracket is for m’s but I have seen some with it and made me wonder.
The cabriolets use a different hold down system over that of the sedan counterparts.
Since the battery tray is part of a floating box (cabrio's flex a lot) and the older more conventional long bolt/clamp is utilized. To retain the battery inside of the floating box.
The part you show would negate any ability of the tray to "float."
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
