1 - 2 of 2 Posts
What's up every one, new to the forum but I have been lurking around for a while. You guys have some good threads. I need some help I have a 2000 coupe. It's been give me a problem. The Traction control light and EML light turn on, car goes into limp mode.
I have changed out the ICV cleaned the MAF cleaned the TB. Checked all the boots for cracks. Itll turn off here and there and the car will run fine if not it goes into LIMP mode. And will run rough.
I'm thinking its a bad TPS??
Thanks!
Premium Member
Doubt the TPS is your issue and you should hope it is not.
Get codes read and report back along with any Freeze Frame and warm idle Fuel Trim info.
Read the first 2 links below in my signature for other problem areas and ideas.
You may actually have more than one problem because running rough and the Traction Control/EML light coming on may be separate issues.
1 - 2 of 2 Posts
