I am looking at a friend's 2003 325i (Oct 2002 build date) with 170k miles that has been losing coolant without any external leak and also suffering from intermittent cold start misfires (INPA codes 239, 240, 241, 242, 243; and P1347/P1349 type codes on obdfusion). This car was overheated after busting a radiator end cap on the highway. Unfortunately, it was driven to a gas station and then towed to a shop where the radiator and some other cooling system parts were replaced, but within about 6 months it began consuming coolant.
The car actually runs very strong but it runs low on coolant once or twice a week on only a 15 mile or so daily roundtrip commute. (EDIT: I spoke further with the owner, and it actually needed coolant once every 10 days or so, maybe every 150 miles.) There are definitely no external coolant leaks to be found, and I pressureized the coolant system and it held 21psi for hours. Fwiw, LT fuel trims are about 7 to 8%, and the DME #3 connector was covered in oil from a leak out of the exhaust cam position sensor.
I did a leakdown test and confirmed leakage into the expansion tank on cylinders 2 through 6, but the actual leakdown numbers on all cylinders are only about 5.5% or so (90psi vs 85psi at cylinder, approximately). Does this make sense? Has anyone seen small leakdown numbers with pressure loss into coolant system?
I'm confident this is a bad headgasket or cracked head, but the low/good leak down numbers surprised me. Never done a leak down test before, either, so can't compare it to anything else, but I did make sure to keep each cylinder at TDC using a breaker bar as best I could.
Fwiw, compression test & leakdown numbers posted below as a case study / data point for anyone esle going through this, and also a video on youtube of a leakdown test on #5 cylinder showing bubbles at ET. Btw, this video was an afterthought after I tested all the cylinders; on the first run coolant was pushed up and out of the tank along with bubbling.
Cold compression test results (1 thru 6):
195psi, 195psi, 207psi, 197psi, 187psi, 192.5psi
Warm compression test results (1 thru 6):
195psi, 180psi, 185psi, 182.5psi, 175psi, 182.5psi
Leak down test results (1 thru 6):
Leakdown test video on cylinder 5:
https://www.youtube.com/watch?v=cWGfozFO8xM
- 1: 95psi input vs 90psi @ cyl; leakage into valve cover (?)
- 2: 90psi input vs 85psi @ cyl; leakage into coolant ET & into #1 (?)
- 3: 90psi input vs 85psi @ cyl; leakage into coolant ET, into #4 & intake
- 4: 90psi input vs 85psi @ cyl; leakage into coolant ET (slightly, less than others) & into #3
- 5: 90psi input vs 85psi @ cyl; leakage into coolant ET
- 6: 90psi input vs 85psi @ cyl; leakage into coolant ET (big), no other leakage
