361 - 380 of 451 Posts
Avin will give all sorts of excuses instead of admitting any defects or software bugs in their products.
Sent from my iPad using Tapatalk
I'll give that a shot! Avin thinks it might be my battery being old, so I have some possible solutions
Well if the battery can start the car im sure it can fire up a little head unit, my one E46 is a little like a garage queen with only 30,000 miles on the clock like brand new and sometimes I forget to change over the smart charger from the E30 back to the E46 and if the voltage is a little under the car will not turn over but the Avant 4 in that one will still work as normal.
So im not so sure about the battery story. and both my E46's have the PX6
Made sure the battery was fully charged since I always leave it on a trickle charger and had the same issue. Of course Avin didn***8217;t get back to me when I told them this. I***8217;m going to try to reset the unit.
Made sure the battery was fully charged since I always leave it on a trickle charger and had the same issue. Of course Avin didn't get back to me when I told them this. I'm going to try to reset the unit.
You right mate they suck at getting back to you however I still believe its the best available at this point in time, give that a bash otherwise send it back for a new one, as I said I have 2 units and they are pretty much a pleasure to use.
And they not too far away from you via UPS or whoever. Just a little south of LA
I am ready to pull the trigger on one. I just keep getting stuck on the options. After reading comments i hear the cameras are ****. Can I buy a better one from somewhere else? How is the mic? Better to buy one somewhere else? Any suggestions? Here is what I got on the order page.
AVANT 4
PX6 (Android 9.0) +$49.99
IBUS USB adapter $89.99
Advanced DSP Chipset with 15 EQ Band $29.99
Wireless CarPlay $99.99
Total price. $569.95
AVANT 4
The best I know for Camera will cost more than the Avin head unit :facepalm: Blackvue DR900S but this one may be better than the Avin one: https://www.amazon.com/XTRONS-Recorder-Camera-Driving-Recording/dp/B07MBYCG4C/ref=pd_ybh_a_72?_encoding=UTF8&psc=1&refRID=38R4XD99PT4ZX34HFCYQ
Rear cam on the E46 maybe do what Overboost done in the earlier posts:
https://www.amazon.com/NATIKA-Backup-Camera-Waterproof-Reverse/dp/B07H852D49/ref=pd_ybh_a_86?_encoding=UTF8&psc=1&refRID=XFTR01GPV8WWP3WE1XC4
Something along these lines without silly led's.
Then I would say you good to go.
Just to double check, how is audio quality? Saw some reports where people had issues.
I have the HK system in my car and am happy with it. Will Avin 4 w DSP help improve?
//Binary is in my DNA
2002 BMW 325i
I have the Avin Avant-4 system in my X5 with factory DSP and the sound quality was vastly improved. Couldn't be happier with mine.
Thanks for the suggestions! That Blackvue looks sick as f#%Q!:clap::clap:
AVANT 4
I just pulled the trigger on this one on the 18th. Still waiting for it to ship. Sure hope it works as advertised because this is a lot of money just so I can see Siri in my car... (amongst other features of course)
2002 BMW 325i
does anyone know where to buy the headunit in europe ?
One of our members also located in Greece had to go through AVINUSA here in the states. That's the only distributor I know of worldwide. :dunno:
I've seen a few of the aftermarket reverse cam recommendations, any recs for the wireless transmitter? Anyone have issues with wireless reliability versus just running wires?
Can someone explain to me how the DVR system works for the front and rear cameras? Is this a chipset within the unit you get if you opt for it or do all units come with this and you are just opting for the software to make it functional.
Seems like a neat feature. I'm looking to get this unit with all the bells and whistles but prefer to source my own parts in the areas I can (ex: the microphone, the cameras)
OG Fanatic
I believe its either the camera itself or the software you download from Adroid. Any microphone will work, any rear camera will work as long as it has an RCA connection. The front DVR camera needs to be USB connected for the ADAS warning to work; however, I was able to get the 70mai dashcam to work from the headhunt with the proripetary app
Can you elaborate on which camera you went with? And I’m assuming that means you did NOT check the add on box for DVR?
Sent from my iPad using E46Fanatics mobile app
I installed the Avant 4 in place of my previous Eonon. I got a forward USB camera, and a backup camera, which I never installed. The front one was only SD, but it worked. I plugged it into the USB port on the Avant4 and it works perfectly, so I guess the Avant is good at generic USB cameras.
I have two functional questions for you other Avant users.
About 1 minute or less from initially starting up the car, the playback volume drops for about 10-15 seconds, then resumes. This is NOT the backup volume reduction - that works when it's supposed to, and this will happen, regardless of me driving forward or being stopped, it's always within a minute of powering the unit up.
The second question is about the Brightness levels. In the settings, I see a regular brightness setting, and it works reasonably well. There's also a night brightness setting that has absolutely no effect on the brightness level, regardless of when I adjust it. 10 PM last night, sliding it to the top and back to 0 showed no change. I could not find any other setting that would say "use night brightness at these hours" or anything like that with a light sensor. Is this just a vestigial setting? I ask because the screen is too bright at night, and I can't dim it any lower. Anyone know how to change that, or is that a 'feature' for the system? It's running Droid 8 OS, not the latest version (9?).
2002 BMW 325i
I would check your "default boot volume" in factory settings (password: 126), in the Others tab.
And you may set " Default Power Status" to " Memory the status of last".
Some have complained about the brightness at night but I guess my eyes are horrible. It doesn't bother me at all :dunno:
