I agree with you shanneba but I'm pretty sure the auxiliary fan kicks on when then A/C is used. I believe the ambient temperature sensor will tell when to kick on the auxiliary fan if the A/C does use the aux fan.
The temperature sensor is mounted under the car in the brake cooling duct, on the drivers side, inside the bumper.
The Ambient temp sensor is not used to control the cooling fan.
The fan may not run when the A/C is switched on.
See page 31 of this link for fan info from BMW:
http://www.beisansystems.com/misc/SEIMENS_MS_420_ENGINE_CONTROL_SYSTEM.pdf
ELECTRIC FAN
The electric cooling fan is controlled by the ECM. The ECM uses a remote power output final stage (mounted on the fan housing)
The power output stage receives power from a 50 amp fuse (located in glove box above the fuse bracket). The electric fan is controlled by a pulse width modulated signal from the ECM.
The fan is activated based on the ECM calculation (sensing ratio) of:
• Coolant outlet temperature
• Calculated (by the ECM) catalyst temperature
• Vehicle speed
• Battery voltage
• Air Conditioning pressure (calculated by IHKA
and sent via the K-Bus to the ECM)
Activation of the electric fan:
When the vehicle is first started the fan is activated briefly (20% of maximum speed), then
it is switched off. This procedure is performed for diagnostic purposes.
The voltage generated by the fan when it slows down (it becomes a generator at this time)
must meet the power output stages programmed criteria. This will confirm the RPM of the
fan, if this is not met the signal wire from the output stage is switched to ground and a fault
is set in memory.
NOTE: If the ECM indicates a fault check the fan for freedom of movement
After the initial test has been performed, the fan is brought up to the specified operating
speed. At 10% (sensing ratio) the fan runs at 1/3 speed. At a sensing ratio of between 90-
95% the fan is running at maximum speed. Below 10% or above 95% the fan is stationary.
The sensing ratio is suppressed by a hysteresis function, this prevents speed fluctuation.
When the A/C is switched on, the electric fan is not immediately activated.
After the engine is switched off, the fan may continue to operate at varying speeds (based
on the ECM calculated catalyst temperature). This will cool the radiator down form a heat
surge (up to 10 minutes).
