1 - 11 of 11 Posts
If you are accelerating hard sometimes you get what feels like clutch chatter in a stick shift car while it shifts from first to second. It is a 2000 328i automatic. I was wondering if this could just be a shift solenoid or if this is a sign the tranny is starting to wear out.
Thanks for your help.
Discussion Starter · #3 ·
I'll check the fluid level and report back. There is never a single spot on the ground after i move my car and i'm not getting an idiot light.
Discussion Starter · #4 ·
Just noticed i left out a HUGE peace of information in my description. This ONLY happens between first and second gear. Brain fart.
Discussion Starter · #6 ·
Update, Transmission fluid not low. I took a picture of the sticker on the Tranny pan but i'm just about color blind and i'm not sure i would have been able to tell what color this sticker was if i wasn't. I did confirm it's a GM unit.
I'm thinking of changing the transmission filter, fluid and second gear solenoid unless you guys have some ideas?
change the fluid. report back.
any luck wit this issue? iam having the same problem after i changed my fluid and the fluid it at correct level, also my car 2000 328ci with the gm trans....
1 - 11 of 11 Posts
