I picked up a set of GEN V DDE's from Evosport earlier this year. They sent me the older style rings which fit so snug around my xeon's that they wouldn't autlevel any more. When I turned my car on at night I saw the headlights struggle to raise up and then level back down. It was like they wanted too but the older style rings I had were holding them in place so they couldn't autolevel.
I worked with umnitza and they were kind enough to send me the new style rings that don't clamp down around the xeon headlights so they don't interfere with the autoleveling. I removed the rings all together and I noticed that my autoleveling still wasn't working.
I had to take my car in to get a fog light fixed and I wanted them to take a look at the autoleveling issue. Before I took it in I went ahead and took out the light boxes as well as the rings so they wouldn't have to work around them . I explained to them that my autoleveling wasn't working. I asked them to check the autoleveling mechnanism under the car to see if that had broken or fallen off. They did check the autloveling mechanism and said it was fine but that the autoleving motor in the headlights was broken and since I had drilled wholes in the back of the housing they would not be covered under warranty. They told me that if I wanted this fix I would have to buy new XEONS!
Does this make sense? Do I have any recourse with them? I told them that I had drilled the wholes in the back of the headlight houseing and I know for a fact that I didn't hit anything. Could anything else be causing my headlights not to level? Anyone else experienced a simalar problem? Any help would be greatly appreciated.
