1 - 9 of 9 Posts
I disconnected my battery to install a new zhp wheel. But when I finished the install and re-connected the batt, my power windows no longer auto up and down.
I thought I read somewhere that there's a way to reset your windows. Can someone point me in the right direction? Thanks!
Hold the window switch down after the window is fully down for 2-3 sec you will hear a light clicth do that for every window.
Discussion Starter #7
Yes, they go down, but I have to hold the switch. Thanks for the tip! This place is great! :bow:
Discussion Starter #8
Holding the switches down worked! Note that the car needs to be off, with the key in the "on" position. The reset did not work while the car is running.
Similar problem - but holding the switches does not resolve it.
Disconnected battery.
Windows would not go down 1/4 inch.
Did window down/up/hold trick for 45 seconds.
Fixed down 1/4 problem and doors closed properly.
BUT - now the 4 way window switch will not raise the windows.
It will lower all 4 windows but will only raise the rear two windows when pressed.
Help!
1 - 9 of 9 Posts
