I need help troubleshooting my automatic air recirculated control sensor in my '05 330i. I'm getting this error:
32 AUC heating
Error Frequency: 10
Short circuit to ground
Error present
Error code: 20 42 0A 51 34 A8 08 11 03 6F
When I clear the code, it comes back immediately. When I unplug the AUC sensor I get the error message above plus this one:
30 AUC Sensor
Error Frequency: 10
Open circuit
Error present
Error code: 1E 44 0A 84 37 A8 08 20 03 6F
I bought a used AUC sensor from eBay and I'm getting the same results. I inspected the connector that plugs into the AUC sensor and it looks OK. I took a multimeter and tested each of the pins on the connector. These were my results:
While touching one probe to ground on the chassis, pins 1, 2, and 4 are indicating a connection to ground. Pin 3 is showing 1800 ohms of resistance to ground. According to WDS only pin 1 should be connected to ground. I've attached a picture of the diagram. So, I believe my problem is that pins 2 and 4 are grounded when they shouldn't be. The wires leading to the connector look fine. Not sure where to go from here.
Can someone test out the pins on their connector and verify which pins are supposed to be grounded? Any idea where the wires might be shorting to ground? Thanks in advance!
32 AUC heating
Error Frequency: 10
Error present
30 AUC Sensor
Error Frequency: 10
Open circuit
Error present
