261 - 275 of 275 Posts
Seems a bit odd to me that you had to shave fender to fit a 225 while MBCO is running 245's with a roll and no issues. He also has H&R cups which are supposed to be lower than the Eibach pro kit, right?
Are the touring fenders more narrow?
That does seem strange, now that you mention it.
Well, I can only speak from my experience and without the fender work, I was rubbing like crazy. I often have a pretty big load: full roof box, full cargo area, me and 3 kids with stock camber specs all around. After the work on the rear fenders - zero rubbing, even fully compressed and performs wonderfully.
MBCO, Do you rub on the rear?
ARC-8 17x9" et30 ------ 235/40R17 ---------- lowered aprox 2" Voghtland Springs w/Bilstein B8 Sport shocks ------------ no agro camber or mods or rolling... no rubbing
I really don’t post enough on e46fanatics. Here’s my Oxford green zhp.
18 x 8.5 et38 Square
Michelin PSS 235/40/18
Wheels are a custom powder coat in prismatic’s Montana gold.
Only under very harsh bumps where it's almost fully compressed.
I also run -2.5 rear camber which helps keep it under the fender
When I ran -2.25 and -2.4 I rubbed smidge more even with rolled fenders. Camber is the key, just not excessive. 2.5 works for me.
Sent from my PH-1 using Tapatalk
Vendor
Reviving this thread from the dead!
Now seems like a great time to bring this thread back! Check out these shots of BuildJournal's track-ready M3!
APEX wheel info:
Front & Rear:
  • APEX 18x10” ET25 ARC-8R Forged Wheels in Satin Black
  • 275/35/18 Nankang AR-1
  • 5mm Spacer Rear
Alignment:
  • -4 camber Front
  • -2.5 camber Rear
2005 BMW 330i
apex 18x9 ET42 Arc8
goodyear exhilarates 245/35R18
koni fsd + eibach pro kit
905760
2000 323iT - Orientblau Metallic
Apex EC-7 ET35's
Tire: General GMax RS 245/40/R17
Suspension: KONI Yellow/Eibach Pro Kit / XI Spring Pad in the Rear
Alignment: ZHP
907476
907478
