Questions?
Call: 925-245-0773
Email: [email protected]
Web: www.apexraceparts.com
Hours: M-F 9a-5p PST
ARC-8R & EC-7R
Everything you love about the original, now enhanced with all the added benefits of forged manufacturing.
- Significantly increased strength
- Improved brake clearance
- Paintless knurled beads
- New premium finishes
Order Now
ARC-8R / EC-7R
Available Finishes
APEX ARC-8R Forged Wheels - YouTube
APEX EC-7R Forged Wheels - YouTube
Even More Strength
"Forged" doesn't mean strong. Many forged wheels focus on weight reduction so much that they end up with the same load rating as cast wheels. Think all forged wheels are stronger than cast or flow formed? Think again. We've added up to 1,000 pounds of extra load capacity per vehicle compared to our flow formed line.
The flow formed ARC-8 was our first design, so it features our older barrel profile with compromised brake clearance. Typical blank forgings (the starting point many other manufacturers use) can have even worse clearance than our original flow formed wheel. By developing our own proprietary new profiles and new dies, the 18" ARC-8R and EC-7R can clear Brembo 380mm kits and the 19" version can clear BMW 410mm carbon ceramics.
Learn more about why we had to create our own new forging dies to clear big brakes.
Paintless Knurled Beads
Not all knurling is created equal. To reduce unwanted tire spin as much as we could, we protected our knurling from paint to keep them sharp. We didn't take the cheaper shortcut of painting over the bead area, which makes the knurling smoother and rounder. See and feel the difference.
Our forged wheel line enabled us to release premium finishes we've always hoped for. Fully polished aluminum and hand brushed with tinted clear now join a wide range of painted finishes, with more to come. Our forged wheels not only deliver performance, but also provide distinctive new styling as well.
APEX is known for stocking a wide variety of chassis specific fitments to meet the needs of a very diverse enthusiast community. We're releasing those same street, track and race proven fitments and more in our new forged line. New lower production requirements allow us to cater to even the most niche segments of the BMW market that may have previously been off limits.
We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn't improve strength. The end result is a fully forged wheel with an ideal balance of strength and weight.
Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX Classic Line forged wheels are tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our forged wheels exceed those ratings by almost 20%. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy.
Learn more about VIA and JWL
Additional Features
Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required.
Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps.
Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn't equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Lifetime Warranty
Let's face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our unique APEX Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices.
Learn more
Order Now
ARC-8R / EC-7R
Fitment Guides
We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides.
APEX Forged Wheel Gallery
Wheel & Tire Packages"
Shop Tires
For your convenience, wheel and tire packages are now available at APEX. Our knowledgeable BMW Product Experts hand pick some of the best compounds available from prominent brands like Michelin and Nitto, and we've priced them competitively.
All wheel and tire packages include free mounting and road force balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse.
Order Now
ARC-8R / EC-7R
Questions?
Call: 925-245-0773
Order Now
ARC-8R / EC-7R
Fitment Guides
Shop Tires
Order Now
ARC-8R / EC-7R
Questions?
Call: 925-245-0773
