Jspeed said:There's nothing special about the Canadian software. Just install a pair of high-flow cats and you'll be fine.
Why not feed the engine ECU with real readings from the O2 sensor and let the whole system work as intended? You'll be doing the environment a favor too.JC7727 said:What happend to the o2 sims.
ya i am going to try the sims if they don't work which i don't think they will as the ECU is looking at multiplicative values from the 02 sensors under load, looks like a high flow cat is in my future.Jspeed said:Why not feed the engine ECU with real readings from the O2 sensor and let the whole system work as intended? You'll be doing the environment a favor too.
