Seeing that you are in Michigan, you should use some sort of heat source to loosen up the adhesive, then floss behind, use it like you are flossing your teeth. Use goo gone, but use a really small ammount, it will strip your paint if you use to much or let it sit. Of all my mods so far, I felt this one made the car look so much more clean and balanced.
