:werd:bluecougar said:I use OEM ones
OE lugs work okay. We send new lugs no charge on 18" and 19" applications.e46boy said:Ch doesn't come with bbs lugs? :dunno:
Thanks for the reply Gary...coming from the experts...OEM should be fine...is it really necessary to mount it with BBS lugs?? Should'nt make any difference since the BBS ones are longer than the OEM??[email protected] said:OE lugs work okay. We send new lugs no charge on 18" and 19" applications.
http://www.tirerack.com/a.jsp?a=BN4&url=/wheels/index.jsp
Depends on the wheel size. We're showing the 18" version comes with BBS bolts that are 2mm longer to give you some extra engagement. Its a small difference, but since they come with the wheels anyway, why not just use them?silber325 said:Thanks for the reply Gary...coming from the experts...OEM should be fine...is it really necessary to mount it with BBS lugs?? Should'nt make any difference since the BBS ones are longer than the OEM??
Feed me..with insights...
Thanks in advance!!
I use the oem on my 18" CH too.[email protected] said:Depends on the wheel size. We're showing the 18" version comes with BBS bolts that are 2mm longer to give you some extra engagement. Its a small difference, but since they come with the wheels anyway, why not just use them?
Makes sense. And we're only talking about 2mm difference in usable length. Should be fine, just check the torque on them periodically like normal.ishoong said:I use the oem on my 18" CH too.
Because the stock black lugs looks better than chrome one on a black car.
Thanks for the response Gary. I have the 19 x 8.5 ET35 CH..so using OEM lugs won't be unsafe since the OEM are shorter considering a 35mm offset??[email protected] said:Depends on the wheel size. We're showing the 18" version comes with BBS bolts that are 2mm longer to give you some extra engagement. Its a small difference, but since they come with the wheels anyway, why not just use them?
According to BBS, the 19" use OE sized lugs.silber325 said:Thanks for the response Gary. I have the 19 x 8.5 ET35 CH..so using OEM lugs won't be unsafe since the OEM are shorter considering a 35mm offset??
True..the OEM looks better coz its black..it will look clean considering my BBS lugs are old already...
Thanks!
Thanks Gary..I feel relieved!![email protected] said:According to BBS, the 19" use OE sized lugs.
