1 - 6 of 6 Posts
TUNERMOTORSPORT.COM THINKING OF BUYING IT, MY FRIEND HAVE IT ON HIS SUPERCHARGER M3.
2001-2006 E46 M3 SCCA T2 Class RACE VERSION Shark Injector
This software was developed on the dyno specifically for our 2001-2005 E46M3 that competes in SCCA's National T2 Class. Like our standard M3's Shark Injector software for the M3 - it removes the top speed limiter , increases horsepower (optimizes ignition timing, vanos and fuel maps for 93 octane gasoline) and is designed for a cat back exhaust, BUT this specific T2 software also increases the rev limiter to 8600rpm and turns off a few of the cars OBD2 systems that could cause the check engine light to illuminate (T2 rules say that the CE light must not be on after the race ! ) This software is recommended for race use only (mainly because of the high rpm limit) but will work on any M3.
yes very nice everyday upgrade ..if you want more aggresive go DA
How does you friend run this on his supercharged M3? Either you are mistaken with what he is running or he is running this and his car is going to blow up faster then a VF car! A supercharged M3 will be running software from what ever company makes the supercharger kit in order to function correctly.
Discussion Starter #4
correction above, he had it b4 having the supercharger..
1 - 6 of 6 Posts
