  • Hey everyone! Enter your ride HERE to be a part of December's Ride of the Month Challenge!
1 - 5 of 5 Posts
I actually don't know where they are in the engine but ETK says on is attached to starter and one the the engine cover. I have to look. But nology sells a earth ground wire for pretty cheap. Might just be a cheap mod and help clear up some of the sporatic electrical probs I have. There was a Japanese dude that did a complete proper ground loop back to the rear negative battery. He said in sport tranny mode the car was more responsive.
I was thinking of replacing the ground cable when I do my Denso Iridium plugs.
Opinions?:dunno:
Discussion Starter · #3 ·
Well I couldn't see the earth ground.
The only thing I saw was a ground attached from the ECU to the firewall. I might add a metal plate behind the ECU ground so it has a good contact or extent another ground cable to another location for that.
I just looked quickly for the others but it might be buried somewhere I cant see in garage light. If someone else knows where it is let me know.
Discussion Starter · #4 ·
I found one of the ground cables. The other I will look later
but the part diagram from the BMW parts cd shows a very small wire like the gound to the hood. I'm going to put a large washer or metal plate behind the ECU ground which seems like they have it grounded to metal that has been painted. Also the eath ground to the hood is a very smal wire. I think I will go ahead and upgrade both to larger higher quality ground wires. I'm going to investigate the starter solenoid as well.
1 - 5 of 5 Posts
