1 - 6 of 6 Posts
I've searched a bit to see if there has been any effective air box mods for the E46 and couldn't find much.
Coming over from the Audi camp, one of the first things I did to my A4 1.8T for a few HPs was to remove the filter screens, cut holes in the box and add a K&N. The result was pretty impressive.
For the BMW crowd it seems like an entire after market CAI is the perfered way to go
It seems like a few good 3-4" holes on the front of the lower box section would add cold air were most of the CAI draws from anyway.
With all the CAI's sold I was thinking of picking up a cheap used box to sacrifice and test.
Has anyone done this effectively?
Dave H
2001 330cic
if you're talking about DIY mods, there're some fanatics who modded their mass air filter sensor screen to improve air flow.... but I have yet to read about modding the airbox.
most ppl just dump the air box, and go for either a CAI, or a short tube intake like the gruppe M or conforti. the reason being, it's not that you're only going for colder/denser air, but you're also improving the flow of the air into the engine. the oem airbox is more restrictive in terms of the speed air travels through, whereas a CAI or a short tube intake sucks in air more rapidly.
Yes, some people have played with the airbox. It as simple as cutting an opening on the bottom of the box and connecting a duct from that opening to the bottom of the bumper.
Discussion Starter · #4 ·
Thanks, I'll try the DYI forum as well.
Jspeed: Do you recall the hole and duct technique being effective?
Senior Eurowerkz Member
do a search to get the information
just get the gruppe m intake take will do the trick for ya. you can
cut a hole where the brake ducts are next to the fog lights to if you like.
bobm3 ;) ;)
Yes, there is measurable improvement. "31st330i" did this mod and measured an increase in airflow w/ an OBD2 tool.
1 - 6 of 6 Posts
