Okay so about 6k miles ago I did a 4 wheel brake job, Including
Stoptech SP pads
BMW Performance Rotors
BMW Brake fluid flush
BMW caliper rebuild kits
BMW Brake lines
Pad sensor (rear)
cleaned guide pins and mating serfaces
Brakes were alright at first and got better after a bed in process from zeckhausen. Then after a thousand more miles I did it again but after I was done I think my brakes were still too hot to stop so I started it back up and drove around till they cooled. about a week or so later I started getting little shakes that progressively got worse. so per or threads I did the bed in again and it was great for a day and then i got little shakes again that progressively got worse. after a while I did this whole process Again, but with more hard stops to try and grind off any residue and same result.
I know FCABS can do this too, however I don't think the cab related shaking would improve with bedding. but I've ordered new Arms and bushing anyways just to be sure.
So now when they come in the mail I plan on checking out my front brakes at the same time, hopefully reseating parts or something might help. But what can I look for that could be causing it as I'm not 100% positive the rotors have pad deposits. And if they in fact do, being 6k old would I be able to get them turned just enough to even em up or are these badboys gonna be trash :/
EDIT: When I felt the brakes were too hot to park. I had parked gotten out, heard ticking, got back in and drove away. The time it took to do that is how long the car was stopped for.
Stoptech SP pads
BMW Brake lines
Pad sensor (rear)
