The car is an 03 330ci, about 102k miles, auto, bone stock. This issue started a couple days ago, it didn't start right away but after a few tries it eventually turned over and started. When the key is turned everything is normal until you try to start the car, at that point the starter does nothing...no click, no flashing lights, you just hear the fuel pump. Here's what I've done so far:
-tried to jump start with no luck, the battery has plenty of power.
-tried spare key but it didn't work, same problem.
-checked fuel pump, it's definitely working
-no bad fuses in the glove box and I'm not aware of another fuse box.
So other than banging the starter with something, what else can I try before I start buying parts? I haven't tried the "tap the starter" trick because I'm assuming I'll have to get to it from the bottom, which wasn't an option last night. If that doesn't work I may just start with a new ignition switch. :dunno:
Are there relays or fuses for the starter in another location? Where is the "main relay" located and how can I test it?
I don't have a bentley manual so any help/suggestions will be appreciated.
