1 - 19 of 19 Posts
I'm thinking of getting angel eyes.
-Did/can you put them on yourself or have them professionally done?
-Have you had any problems with them?
-What are the best ones to get?
Post pics!
There's already 78,000 threads like this. I see you're new here. Welcome. But you should see my sig for important maintenance info and do it all if you can swing it financially. Angel eyes should be the least of your concern right now. A bad install can cause a fire (even an engineer installed a set i sold him and nearly set his car on fire) so i'm not sure a noobie should be installing them. either way, maintenance first, mods later. GL
Discussion Starter · #3 ·
Yikess! Thanks for the welcome & reply! I'll check it out. Maintenance, check! Can I mod now? lol
Predator Orion V2's FTW! I installed them when I was a "noob" 4 years ago and haven't had a problem since. The install is really easy.
Discussion Starter · #7 ·
Love it! I'll check those out. How is installation with the self adjusting headlight sensitivity? I was worried it would interfere.
I don't even have 50k on it yet. Should I still replace the cooling system?
I would. The parts don't only go by mileage, but by age. I would at least change the expansion tank, hoses, a/t cooler o-ring, water pump, t-stat, belts, and pulleys. your car will go as far as your wallet can take it.
if you should get caught in a overheat, shut down the engine immediately. if you don't notice it overheating though, there goes the engine. that's why it's important.
It will interfere. That's part of the reason I sold mine. the rings kept popping off during the auto-leveling despite modifications/tape. apparently this is a common problem on facelifted sedans.
On my facelifted sedan the rings haven't popped off once thnx God, and I use my car 5-6 days a week after sundown when the xenons come on.
Nope no problems
Shifting
Discussion Starter · #17 ·
DIY is easy if you are a bit handy with simple tools. here is a guide for installing the lights:
http://fastm.com/m3/angeleyes_orionv2.html
As for which ones to get there's either regular budget lights or the top end
Budget:
http://www.umnitza.com/orion-lite-60-generic-led-angel-eyes-p-5686.html
High end: (what I have)
http://www.umnitza.com/predator-ori...-p-1198.html?zenid=jb097f9jerl9l45pr83ns26nr5
What's the difference between the high end & the generic? I hear much better things about the V2!
Shifting
The V2's are constructed better and the LED's do not fail at all. They also come with built in clips and the quality is superb. As for the lower end angel eyes, the ones I posted are pretty much the same (people might argue that but I've done 50 angel eye installed with various brands and they are all the same) the LED's can burn out after even as a few months, the clips also have to be inserted to the rings but that's easy.
The V2's have less LED's and they are physically smaller, and the cheaper rings have more LED's but are overall bigger filling more of the headlight to make it look cleaner. I'd rather take more brightness/better quality over rings that fit maybe a bit better but can fail fast.
Discussion Starter · #19 ·
I'd also rather take quality overall, otherwise I would have bought a Honda :p
1 - 19 of 19 Posts
