1 - 6 of 6 Posts
Just received my LED angel eyes from Umnzita the other day and I JUST installed them. Prior to installation I tested both with a 12V battery, they both worked fine.
I have now wired my car 100%, have both of the headlights re-assembled and now the passenger side Angel eyes are not working. I checked my connections to the wiring harness to see if I had a loose connection there, but that was not where my problem was.
Any suggestions/input? Any would be appreciated. Thanks!
[Edited for LED angel eyes]
Discussion Starter · #2 ·
Shameless self-bump
I tested the Black (Negative wire) with the positive terminal of the harness that was working and the lights that were not illuminate lit up. So it seems to be a problem with the positive part of that harness. Possibly a bad connection?
Discussion Starter · #6 ·
No the wire is dead on that side of the harness.
I might just end up splicing into the other positive wire, run it across the top of my fan to the light harness (which works)
1 - 6 of 6 Posts
