Ok SO,
Got an AE kit, it's all mounted, grounded and attached to the positive terminal.
The instructions direct you to tap into the accessory wire on the driver side so they'll constantly be on. Not a fan of that. Ideally I'd prefer to have a switch on the driver footwell to turn then AE on and off as I please. Needless to say other than the basic connections I haven't tapped it into anything yet.
I have a long white wire coming off the passenger side that turns the halos on when I touch it to the positive terminal, and a much shorter read wire on the drivers side that the kit company recommended I tap into the accessory wire with. I have a relay and fuse attached already.
So my question is, based off of what I've already done, is there any way I'll be able to wire in a switch on the driver footwell so I can turn them on and off at will?
